FS: 90's Vespa Ciao Mix NYC
Need to make room in the garage, so this one's gotta go. I can't date the bike exactly but it has to be a 90's model. Imported by Dos, this thing is super neat. Single speed, Oil injected, with Euro cases that have the really good intake patch. I cleaned the tank, polished the paint, replaced all the seals, and threw a bunch of nice parts at it.
43mm Malossi kit/head
Pinasco lightweight flywheel/stock CDI
Moparts Racing CNC clutch bell
12:12/Malossi filter
Gianelli city pipe
It's a ripper. Does low/mid 40s with the stock 100mm rear pulley, and gets there pretty quickly. Takeoff is quite good with malossi yellow springs, might be even better with white or black. The lightweight flywheel really helps it out. Quiet and makes good torque thanks to the gianelli pipe, but it revs out really well too! Also, this thing has by far the best drum brakes of any moped I've ever ridden, it stops amazingly.
Registered as a class C with transferable NY registration in hand. You'd be hard pressed to find a cleaner one.
I'd like to see $1600 for it as it sits. Located in Brooklyn NY.
  FS: 90's Vespa Ciao Mix NYCTopic by: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/12/21 09:53AM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Stephen Keller Stephen Keller 05/12/21 05:10PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: John Simpson John Simpson 05/13/21 08:45AM
  Re: FS: 90's Vespa Ciao Mix NYCRe: campeona del mundo campeona del mundo 05/13/21 07:51PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 05/13/21 09:56PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Stephen Keller Stephen Keller 05/14/21 12:45AM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 06/07/21 07:33PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 06/22/21 01:47PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Stephen Keller Stephen Keller 06/25/21 02:55AM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 06/30/21 09:23AM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Dirty30 Dillon Dirty30 Dillon 06/30/21 09:53AM
  Re: FS: 90's Vespa Ciao Mix NYCRe: J o h n J o h n 06/30/21 04:46PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Stephen Keller Stephen Keller 06/30/21 05:09PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: campeona del mundo campeona del mundo 06/30/21 01:06PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Gianluca Coco Gianluca Coco 07/03/21 08:56PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: lucien vogin lucien vogin 07/05/21 12:46PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 07/05/21 04:10PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: Stephen Keller Stephen Keller 07/05/21 11:44PM
  Re: FS: 90's Vespa Ciao Mix NYCRe: campeona del mundo campeona del mundo 07/06/21 05:00PM
