Looking for a performance pipe for a qt
Treatland is out of stock
Maybe there's one floating around out there?
Do pw50 pipes fit qt50? They should since both are single speed transmissions
Edit: googled it And it appears the answer is yes. (edited)
Got a brand new circuit pipe in the bag that I was saving for a future project. Your welcome to make an offer if interested.
Was hoping to get a peoples sidebleed because my understanding is it's better for top end where the circuit helps more with low/mids, which I think this QT does pretty good on already. On the other hand the sidebleed is pricier so I'll mull that offer over - thanks Jimmy
id personally recommend getting a big bore kit before a pipe, as it'll give you more benefit with a stock set up, i used the cheapo 60$ one meant for a Pw50, bolts right on.
Link? For that price seems worth trying
Nice, thanks!
FYI, shop around on ebay and you will find that kit for around $30 shipped. Also, clean up the casting on both the piston and the cylinder really well before running. Any complete top end for that price is gonna have some flaws. Ive purchased 2 of these kits before and both seem to run ok. You will not see any additional top speed but the low - mid range improves.
That mlm circuit pipe is about 2 mph faster than the people’s pipe. Mlm’s dimensions must have been wrong if they intended it to perform like a true circuit pipe.
Huh - here I thought the people's pipe was a faster pipe
Had both and ran them back to back. I don't have my people's pipe anymore. People's pipe has much longer header which is not so good for top speed.
