Re: WTB Puch (bing) carbs bodys and intakes
Probably Fred /
> Tommy K Wrote:
> I have several maxis that need carbs really just bodys (I have a crap
> ton of parts to rebuild) cause the original ones leak and its not seals
> either, (stripped in some place or another) 12 or 14 mm is fine
It has little to do with the bodies,
it’s with the float valve or the float seats or the float itself, look on wiki to correct the problem and try to fix it.
Chances are you going to get ones that doing the same thing you have to be a little crafty to keep the leakage down,
