WTB Puch (bing) carbs bodys and intakes
Tommy K /
I have several maxis that need carbs really just bodys (I have a crap ton of parts to rebuild) cause the original ones leak and its not seals either, (stripped in some place or another) 12 or 14 mm is fine
Re: WTB Puch (bing) carbs bodys and intakes
Probably Fred /
It has little to do with the bodies,
it’s with the float valve or the float seats or the float itself, look on wiki to correct the problem and try to fix it.
Chances are you going to get ones that doing the same thing you have to be a little crafty to keep the leakage down,
Tommy K /
amf OP
Thanks for your advice but it has alot to do with bodies, some morons worked on em and stripped the float boal on the carbs themselves.
i may have a couple 12mm Bings
also i KNOW i have 12mm intakes, round ports
Tommy K /
amf OP
Update. found what I needed. Thanks!
I have two 12mm bing bodies and intakes.
PM me with a phone number I can send some pics to.
