A red (800) and a yellow (750) Pinto available. I'm in Oakland, CA... you can pickup here, or I can pass 'em off to your uship driver, or I can box+ship (it's been a while but last time I did it I remember doing a partial disassembly with 1 bike box + 1 large box, and it being around $150-200). I also have a decent sized car and could drop em within an hour or so for gas money (after payment has been made).
Nothing major, but for your records --> I’ve done the following (that I can remember): Shipped em rough to the Bay Area. Cleaned and rebuilt carbs (installed new float in the red, 2.22 atomizers, metering needles, metering needle clips, throttle spring in the yellow, top gasket, float bowl gasket, nos #24 carb slides, jets, etc). Installed new OMG gold petcocks, clear karcoma filters, and motion pro clear fuel lines. Put on new Dos circuit exhausts and crush gaskets. Installed new metal mesh air filters. Repacked loose bearings on front and rear wheels and cleaned brake parts. Installed new brake shoes for rear wheel on the red, deglazed others. Installed new tubes and new sava mc11 tires (17x2.25) on the red (yellow kept old but decent tires with no cracks). Installed new 415 and pedal chains. Installed and gapped new spark plugs. Added cute little original Bluemels tire pump under sidecover on the red. Replaced bars with stock bars on the red. Installed new brake light switch on the red. Inspected lubed and cleaned cables. Drained and replaced tranny fluid. Torqued all bolts to spec. Cleaned all paint/chrome/plastic surfaces, evaporust-ed rust and used rustoleum on red’ seatpan and inner rims Etc. Original exhausts, air filters, side cover bolts and side covers included.
Both now in good shape. Yellow slightly less $ due to some old pitting on the tank, minor seat tears, and not needing/getting new tires or tubes. (edited)
