A35 Tomos Parts FS
Dan Ackroyd /
A35 engine with new corked clutch’s / a35 CDI (I had to drill the plate to make it work it’s an old points a35 engine case) brand new airsal 50cc kit and a mismatched high comp 70cc head from a dmp puch kit works though 26sprocket
CDI coil sold with engine
Pedal arms with pedals sold with the engine
$320
Frame with swing arm and seat rear light (fender is broken) $90
14mm sha carb with metal filter ((can be sold complete with engine as well) $45
Front triple clamps (yokes) / tubes / fork headlight covers / forks have been regreased and all spray painted engine case satin black $85
Treatland square headlight $20
Grimeca wheels 16inch (they are pitted tans sprayed painted gold ) brake plates will need to be made to work etc one axle I have new bearings in there one is not pictured 80
I have a brand new set of Mitas tires and tubes if you want them included as well 110 with tires
Wiring harness with controls $75
lX handlebars $30
Swing arm and front fender $25
Pedal shaft $15
Take off shocks $20
Or with you want the whole lot make an offer on whatever you see guys and gals thanks again as always
I’m located In the Philadelphia area for local pick up
Everything BEST OFFER I don’t know what it’s worth etc easier to part out then put together
PayPal and Venmo everything ships ups ground
Re: A35 Tomos Parts FS
Dan Ackroyd /
Photos
Dan Ackroyd /
Side cover not included sorry will get better picture of this frame !
Why?
Dan Ackroyd /
Some things came up sadly 😢
Erwin Schrodinger /
PMing about wiring harness and controls
