** PLEASE DO NOT PM ME - EMAIL ONLY: drlegendre@gmail.com **
** Rather than sell these off one at a time, I'd like to solicit offers for the entire lot. Here's a list - I don't have a parts manual for these bikes, so not all have part numbers.
All items are FOB St Paul, MN **
Piaggio / Vespa parts
These are all for Ciao / Bravo / Grande unless noted.
Reflector, headlamp, CEV x2
Speedo drive, Veglia x2
104862 Plate x3
113910 carb float x5
130240 brake / clutch shoe, lined x1
Washer 1.094" x .605" x.047" / 28x15x1.2mm x1
Cable, clutch or R brake X1
Cable, speedo x1
Speedometer, 40mph, USA, CEV x2
123389 screw x6
Cable end toggle / Knarp x5
123391 screw x5
103218 cable x2
122957 spring x11
S.011753 shearing woodruff key x4
114219 crank cotter x3
Hollow metal pin x1
Chain idler assy. X1
Brake lever spring x1
Latching fastener x1
149275 bracket x1
Shift fork? X1
114215 nipple, spoke x21
135694 brake cam x1
113708 crankshaft & rod assy. X2
152196 Top end assy (cylinder w/ fitted piston & rings, cyl. head) x1
Primary driven pulley assy. w/clutch shoes x1
Vespa Scooter rear luggage rack mounting hdwe. kit, sealed
Manuals
Assy & prep Ciao x2
Assy & prep Bravo x2
Assy & prep Grande x2
