I have two bikes I want to sell as a package. The story goes.....the lazers tank was dirty and I had some sort of electrical issue so the bike got parked. Polini kitted v1 with 15 sha. I got the motron with a bad motor so I tossed it on and started building it. Never finished it. I have the motor for the motron but it needs bearings. Ran great but had a loud bottom end. So basically you get two bikes and can build the clean lazer or what ever. Lazer has low miles and the polini kit has about 300 on it. Was my girls bike so it never got beat on. Tank needs to be cleaned and electrical figured out. I dont remember what the issue was now? Motron has new tires with mabye 1 mile on them. Has yamaha yg1 front wheel, light and speedo. Brake is huge. Was running when put away six or so years ago. I'm sure if I clean the carb and toss some fresh gas it will run. Also have a bunch of sprockets, some carbs, the stock pipe for the lazer. It's cool it has like a rocket on it. $1000 for all
Lazer sport 50 and motron
Re: Lazer sport 50 and motron
Not sure what is up with the plumbing piece on the headset? Way it came when I got it. Also missing headlight and ring. Not sure what happened to it.
Got another stock jug and piston and mabye another parts bottom end.
May trade for vespa scooter project or small cc motorcycle? Like old hondas.
I'm in maine, close to portland.
I will make sure the engine is running. It was never fully tuned with this pipe.
I forgot how nice the lazer was. Probably the cleanest one I have seen. I should just fix it up and ride it but I have so many projects that need to be finished and this is not priority.
Damn if you were closer I would take these. That motron! The color!
I got the fenders for it also.
That Lazer is beautiful...and what is the pipe on that Motron? Too much space between us otherwise I'd have a Honda Trail 55 to barter for these.
GLWS!
> these.
> GLWS!
Pipe I built. It is based off the proma warrior
What a steal, wish I was closer
Is that a yg1 front wheel and speedo on the Motron?
Yes. Has garelli fork also.
