MB5 Engine
Cameron Cate /
Swapped this out of my MB5 right after I bought it. I have never run it because i dont have a carb for it.
Turns over smoothly, good compression.
Reeds are in good shape.
Clutch works fine as far as I can tell without running.
Shifts smooth through all 5 gears.
Trans has been sitting filled with clean oil.
No moisture damage inside trans, crankcase or stator.
Strong spark.
Cylinder, rings, and piston are clean from looking through the ports. I have not had the top apart.
Oil pump is not shown but is included.
Includes everything pictured minus the shift lever, that turned out to be broken when I removed it.
$300 shipped or local pickup near Seattle.
