Hi, trying to see if there are any original pedals and arms for my 1984 mini maxi. I like to keep it stock. Thank you
I believe its more commonly known as a Dart. Are you looking for specifically black chrome (which i think they came with) or just arms with the proper dimensions / length. Because you should post a pic or some measurements of what youre after
your pedals and arms are totally correct, and are chrome on dart, and mini maxi. added a pic of mine for reference. mine is oem correct, and never been messed with. the only thing missing on my bike is, on the rack there is a grab bar the same gage wire as the rack. they are commonly broken off from use. both my dart and mini maxi are missing that grab bar. i notice yours is broken off as well.
Wow, super clean beautiful ped. What size exactly are the arms and what pins work the best? Thanks
arm is 6 1/2 inches. pin is standard puch size. check the pin size you have. i forget what it is at the moment. i take it you are missing a pedal?
Yes missing a pedal. My buddy welded it back on but what new.
