ZA50 First Speed Gear
The other day was riding around on the moped when the transmission started making some clanking noise. Opened it up and saw that the first speed gear was cracked and missing a couple of teeth. I've been looking online for parts but can't seem to find them anywhere. The sites that do show them are sold out. If anyone would like to sell me one or let me know where I could buy one I'd be very grateful. Thank you!
Moped: 1979 Puch Maxi 2 automatic
Searching for: NOS puch ZA50 first speed gear - 70T
Re: ZA50 First Speed Gear
What’s that crazy looking toothed thing going around the inside of the gear?
Major bummer. I'd take the rest apart and check the center bearing as well just to be sure
john cervini /
Mach1Vmotors on Ebay has a bunch of nos puch parts listed. I believe there is a nos first gear available.
Probably Fred /
They are the biggest rip off of anything I’ve ever seen, they charge seven dollars shipping for a m6 nut or washer
Um, why hasnt anyone mentioned the cause of this yet?? Shift pucks. Or rather lack of.
Facts ^
Got it THANKS!!!
> Brian I Wrote:
> Got it THANKS!!!
Not a problem
Take a hard look at the drive gear for that also. If it got roughed up when first gear failed, which kind of looks like in picture, it will just eat up a new gear. Hate to see good money thrown away.
Dirty30 Dillon /
> gear?
That's the mech that holds the springs for the one-way rollers. Because the gear cracked, it launched the cover and exposed the guts.
I'm going to say that tranny needs to be stripped down and de-fragged
> > gear?
I've worked on a bunch of Za50s and don't think I've ever seen underneath that cover, pretty funky!
Beach Club Nick /
> the
> > > gear?
> Because
Any ZA you get you need to open up the transmission and replace the shift pucks. 99% of the time they're disintegrated
sorry to raise this one from the dead but same problem - need one - any ideas? found one on ebay that has the correct part number but pic is from the wrong part and it is from Mach1Vmotors used so not surprised...help please
Eventually someone's gonna need to replicate these gears cause too many peeps don't know how to change the shift pucks that cause the damage
Probably Fred /
Even if they do know how change no one wants to take apart a stock original engine that otherwise seems to be running perfect.
I myself have been guilty of it on a stocker but never on a kitted bike. You’d be surprised on other damage and things you’d find like defective/smashed bearings from the factory when you first take apart a za50.
Shift dampener pieces unless large pieces break off at once don’t necessarily hurt the gears but the abrupt non-dampened shift is what hurts the gears and it’s almost hard to tell until the damage occurs but if somethings running good it’s just human nature to leave it alone.
Not sure if I should move this to the general discussion: I ended up finding a used one; however still dealing with a perplexing issue - as this particular gearbox was fully rebuilt (pucks, bearings, shims wt plastigauge, the works) and was shifting smooth as butter for the first 300miles or so; second gear is flipped, gearing is 19T front 35T rear and the bike is now running stuffy crank, a 65cc Metra kit with 15MM bing - pretty mild setup that should not have resulted in anything. Prior to the full rebuilt the bike came with a sheered off crank - literally - the half into the gearbox was detached from the engine half, was also previously opened by someone to look at the damage. All parts were visually inspected, reasembled with proper shimming, torque on nuts, etc. - so let's hear it - if it ain't the pucks - what do you think it was - invisible microfractures from when the crank event happened? Gearing too high? (edited)
