FS: Puch and hobbit stuff
Fs, pm offers, you pay shipping, more pics upon request.
Puch stuff:
Front fender off free spirit
Rear shocks, maxi and free spirit
Stock air box thing
Stock #2 head
Free spirit stock pipe
Right side plastic cover free spirit
New Maxi side covers with assortment of side cover bolts because i dont know man, 9 bolts, some long some short. You figure it out.
Stock crank with some crust but decent shape, little play in crank arm
Og 65cc cast iron metrakit. Broken exhaust stud, someone drilled it out off center. Needs to be tapped and would need an exhaust flange modded to fit it right.
2 rear snowflake brake plates, one with arm, one without. (Sold)
Skinny spoke loose bearing rims with irc 2' tires, good tread, no brake plates, no rear sprocket, no speedo drive. Loose Front bearing repacked, rear is good but could use an new pedal drive freewheel.
Hobbit stuff:
Treats black pipe
Solo seat. Needs new cover
Stock points igniton
Headlight bucket with speedo, and key, headlight, headlight.
Stock carb w/ intake (choke lever is a bit bent)
Crank with needle bearing. Not sure if its stock or aftermarket but its in decent condition.
Malossi Tortion control coupler for motomatic gy6 pully so yah contra spring doesnt fly outta place.
Rear pully, rear outter cheek sold together ( attempted to open pully and rounded the threads on it, thats why yah get the new outter cheek with it)
Gy6 yellow and blue contra springs
3.3g malossi rollers
Tjt derbi rumpus plate modified to fit hobbit tjt
Front break horseshoe spring
Starter clutch arms with the little springs.
Front plastic fork plate thing.
New enc rear brake pads
10x36x6 piston pin. Not sure what piston its for, but its made in Italy. (edited)
Re: FS: Puch and hobbit stuff
How much for the hobbit pipe?
$140 shipped
How much for the hobbit fly wheel? Also, how much for the chrome flywheel cover?
Honda ignition and maxi side covers sold.
Looking for a first speed gear
Sweet! good luck?
Bump
Things sold:
Treat pipe
Honda ignition and cover
Honda light, crank, front plastic, starter clutch arms
Puch maxi side covers
