WTB a 6 volt Starter Relay for a 1981 Honda Passport C70, 1982 - 1983 will not work, They are 12 volt relays, Must be a 6 volt, Honda Cub 6 volt may work also, PM me if you got one, Thanks
Those are very fixable, easy to take apart , if the contacts are dirty or the coil wires need resoldering.
Dude you can buy em anywhere. Try dratv.com first, best horizontal Honda parts dealer online imo.
9 times out of 10 the problem is in the handle bar switch/button. i ended up having to put a second button on my dad's because i couldn't get it to work. just stuck a simple momentary push button in the plastic side cover.
