> Graham Motzing Wrote:
> yeah .3 mm is a common first overbore
> you might be able to find an OEM or another aftermarket like SPI or
> Vertex that is a lot cheaper than wiseco.
> i'll buy wiseco for something really nice and racey but usually i stick
> with the cheap ones... they made KE100's up until the early 00's so it
> shouldn't be too hard to find shit for them
> i would say that if you have the choice to go with a plated bore vs.
> iron, you're probably money ahad grabbing the plated bore, especially if
> you plan on keeping it. You won't have to pay to have it bored/honed
> and it wont wear out as quickly. Plus if you get to the max oversize on
> an iron bore its junk... plated bores basically last forever and you
> just replace the cheap piston for this motorcycle stuff.
He will never put the miles on two wheels like I used to plus he has several bikes so he should get the second over bore piston and get it bored to that size,
It could be good for anywhere is from 5 to 11k miles due to the low RPM of these bikes,
Kawasaki is my favorite two-stroke enduro and or street 2t bikes they just plain rule,
Had a kh400 from 7K to 14k mi untouched, though the compression was low and a bit harder to start especially in cold weather and pretty sure the the rings/top and was toast still started and ran fine once warmed up, I cried when I had to sell it due to being laid off,
