WTB m01 engine mounts
Terbo Speghetti /
To be clear, i want the mounts for morini single speed piston port. If they HAVE TO come attached to a whole frame, so be it. But really, just the mounts is what I'm after. Can pick up in Illinois, Wisconsin, Michigan, or if I absolutely have to, Indiana.
Lmk? Kthx (edited)
Re: WTB m01 engine mounts
What frame are you needing the mounts from? Those motors were used on a few different peds. Are the m02 and m01 the same?
Terbo Speghetti /
Not sure if m02 are the same, maybe someone can chime in. And where they come from isn't important, they're getting chopped off and put on a moby
I have a spare Pacer SS frame. I would need to ascertain its condition before deciding if I want to hack it up.
Terbo Speghetti /
If it's nice at all, don't waste it on me. This is a dumpster bike and it deserves dumpster parts
I understand. Pacer SS frames are hard to come by. If its bent or otherwise damaged I'll consider butchering the frame. Will be a couple of days before I can get it out and look.
The M1 has a wider top mount on one bolt, but I'm not sure on the MO1. It might have the same width as the MO2.
I'm not in Ohio so I can't check.
As far as m01 and m02 are same width I have an m02 Stamped as an m01 cuz they had an excessive amount of left over cases wiki also says this
Thanks!
Terbo Speghetti /
Thanks for the tip! Still looking for a set of mounts tho haha
