Rare parts from Europe for Peogeot 103 -105 and Av10 -av7 Stroker Crankshafts..
Some parts are custom made , if you purchase crankshaft , pulley, bimotor ,direct drive race variator ,
Some of the parts are not in stock : but can get them quickly ...
103 105 kick start with Starter or without starter
Malossi-Ducati Ignition
Av10-AV7 Kick Start
Very difficult to find new and used Gilardoni Orjinal and Aftermarket 46mm Cylinder kit W shaped exhaust ( Capable of 120-130km - 80mph + ,without any fancy variator , spring , pictured engine reaches 80mph ) will add picture tomorrow
19mm Carburetor and Manifolt
Union Headlight
OEM Eurocilindro Cylinder
Roller Bearing
Race variator _ acts better than the Gradio , attention this is a direct drive variator
Custom made Pulley ( you pick the gear between 11 and 18 ), Pulley has Zero Balance with roller bearings on both sides which will last forever .
Bimotors are manufactured according to your needs: such as carburator ,cylinder , crankshaft ., exhaust ..
Special custom made 1 , 1.5. 2, 2.5 mm stroker crankshafts for Av10-Av7 engines , Attention case needs to be shaved according to your stroker...
Page did not let me attach more pictures, will be adding detailed pictures daily.
If you need anything please contact me . Thank you
Re: Rare parts from Europe for Peogeot 103 -105 and Av10 -av7 Stroker Crankshafts..
Not pictured but
EBR forks new or used
New or second hand 48mm Peugeot 103-105 cylinders, I dont think they were realesed in the states
Athena- Euroclindro Racing Carters for AV10 Motobecane also available will add pictutes daily
I’m interested in a lot of this stuff and I’m in Houston. Pm coming
Holey smokes electric start peugeot! What what what!?!
Yes , that is very rare even in here , very hard to find , it is an OEM product .
There are two versions , one with electric starter, and kick starter together
the other version is only kick starter model.
Both models housing is aluminum . You can polish them for a better look.
Oem aluminum kick start for Moby
custom made direct drive race variator
custom made 2 speed or 3 speed variator cheeks ,
custom made pulley with roller bearings. if you need any info and or price on them pm me.
i am adding pictures for 46mm Peugeot Gilardoni( most likey used , brand new ones are still availble , but they are asking too much and 48mm Peugeot Cylinder ( I can get this new or used for you )
I dont have these in stock but can get them quickly...
Im interested in the mobi race pulley and the kickstart.
Sure how many many tooth ? There is black and chrome version of pulley. Which one do you prefer?
And plastic or Aluminum kick start?
reynie domingo /
Mbk has a 41mm stroke, what’s that striker crank have?
MBk has originally 41.8mm
They are all custom made
so you can have
41.8mm plus 1mm
41.8mm plus 1.5mm
41.8mm plus 2mm
41.8mm plus 2.5 mm
crankshafts , It is up to you !
Please let me know , I can have it manufactured according to your needs. Thanks
reynie domingo /
How much $
Hi! Looking for a crank for a Peugeot 105.
bimotor
motors
Yes, the same stroker long race cranks are available for Peugeot 105 engines ,please PM me. Thank you
Gilardoni 46 mm Av10 Cylinder kit , used or brand new orginal or aftermarket kits are avaible.
Eurocilindro-Athena carter for Av10
This is huge.
