peugeot 103 for sale. $525 for ma folk. could use more variator tuning as it's slow off the line. copy paste from cl ad https://sfbay.craigslist.org/eby/bik/d/albany-1977-peugeot-103-moped/7056136556.html
"This bike has had a ton of work done to it and currently runs well with working bright lights, bulletproof CDI ignition and a 70cc big bore kit. There are only a few hundred miles on the bike since it was overhauled. The wiring harness has been simplified and hardwired to remove all the electrical gremlins. The original super finnicky 12mm gurtner carburetor has been upgraded to a dellorto 15mm sha, giving the moped more power and making it way easier to work on and adjust. The original variator has been modified for better take off and hill climbing power. This bike is quiet due to the high flow aftermarket stock style pipe and goes a solid 40mph. The inside of the gas tank is spotless which is a major plus. I just installed a new set of sava 2.5in tires which are a little wider than stock and make the bike a nice comfy ride. "
