NOT A MOPED -$800 1982 DODGE RAMPAGE FOR SALE CHEAP!
Terbo Speghetti /
$800 price only for moped peeps and only if I get the money before I leave for Tampa on Feb 5, price will go up after that!
New pics coming in a couple days, but here's the low-down:
Brown 1982 Dodge Rampage MINI TRUCK
Located in Chicago western suburbs, could be driven a short distance to it's new home.
The good!:
Clean title
Runs and drives, all trans gears are functioning.
Auto 3 spd, FWD
2.2L carbureted engine. Starts every time! Shockingly reliable. It's a rebuilt Jasper engine, should have tons of life left in it.
Truck comes with the original factory service manuals.
The not good:
Needs new rear drum brakes, got em in a box
Needs a gauge cluster installed, also got one in a box.
Could also use an alignment and a set of tires before you drive it too far.
It's got some rust in normal places like rear wheel arches, but for an 82 it's shockingly good!
PM me to put this unicorn in your stable and get me to Tampa!
Re: NOT A MOPED -$800 1982 DODGE RAMPAGE FOR SALE CHEAP!
Tiiiight
Uggggghh such a good deal!!
Pushrod Fifty /
Never saw one before! Perfect for bringing a ped to a rally. They put the same engine in every car and van they produced back then, had a minivan. Everybody badmouthe 2.2 for being dogs but I had mine running sweet.
Angry Hipster /
Very cool, I just learned about these a few months ago.
Good luck with sale, excellent price!
Where was this deal two months ago when I bought mine? Dang.
Ohh my God Soo fucking sweeeeeet.
Ian t’s old rampage still is the raddest one Ive seen to date. This is pretty chill for $800 tho. Glws!
Terbo Speghetti /
I'm sad it's been two hours and nobody bought it yet.
Terbo Speghetti /
Sale pending!
Terbo Speghetti /
SOLD!
2.2 and 2.5 l are good motors i ran a bunch of them , even have a rebuilt head if anyone wants , trade secret is to loosen the a/c alternator bracket around cyl #1 it stresses that section of the block under thermal expansion , 2.2 probably doesn't have that problem but the later 2.5’s are so thin you cannot overbore .
Love those things, great deal.
Pushrod Fifty /
If the distributor shaft gets sloppy on yhe 2.2, the timing jumps around giving a nasty off idle hesitation. I went through a bunch of them to finally get one that was really new and tight, the auto parts store brand name "new" ones were really just cleaned up sloppy used ones. With a fresh timing belt, good distributor set a little advanced, vacuum leaks sorted and a new valve cover gasket and sealant, the 2.2 is a dependable peppy motor. You can adjust the downshift switch on the carb just right do get a downshift just when you want it.
I think the 2.5 was a Mitsubishi engine, didnt have any more power than the 2.2.
2.5 is a Mitsu engine, biggest issue with the 2.2 was the carb the butterfly shaft would wear a hole in carb body, causing an air-leak and a no idle situation. Ex-gf yrs ago had one. Turismo.....always wanted a rampage, but with the 5spd like hers had.
Not surprised the only other person I know with a Rampage is also into mopeds.
Who got it??
Terbo Speghetti /
Alex from the Cranks
