You are supposed to bottom out your studs. When you tighten the nut, YOU SHOULD NOT BE TURNING THE STUD.
ANY mechanic will tell you this is the case. You never want to be applying torque loads by pulling steel threads through aluminum threads. This is specifically a great way to fuck your stud holes.
