I found the problem . While looking at the parts in the carb rebuild kit I noticed a washer in the seperate bag with the needle brass valve and c- clips and knew right away what was wrong . I must have lost the washer I put another in ,put it back together and no leaks,you were right about the washer and by looking at the cut away drawing it’s easy to see why it’s so important. Thanks again
Re: C100 exhaust
