WTB Korado rear sprocket
Terbo Speghetti /
Looking for 39ish teeth, but beggars can't be choosers
Re: WTB Korado rear sprocket
Trevor Fladwood /
I changed mine to a 40 in the rear.. there was one on treats that works..
Found it:
https://www.treatland.tv/moped-rear-sprocket-p/rear-sprocket-98mm-40t-black.htm
Hope that helps!
Terbo Speghetti /
Thanks! It's definitely a start! I'm going down an inch in wheel size so going bigger isn't exactly what i was hoping for. But def good info to have! And maybe i have some room to compensate with a change in my front sprocket, haven't checked yet.
Trevor Fladwood /
Isn’t it a 45 now? Mine was. If you want a 39, this is virtually the same thing. You can get bigger in front but might need to grind a bit of it is a real Korado e50.
Are you using the Bernardi 3 star wheels that come one Korados, or what do you mean by going down an inch in wheel size?
Terbo Speghetti /
The only korado anything in this equation is the wheels. They're going on a bike that came with 17" wheels and a 39 tooth. The korado mags I bought came with a 39 tooth as well, but it's worn way too sharp to use.
Puch snowflake sprockets fit on Korado 3 blade wheels, only like one hole lines up, you have to drill the others, but thats easy, toss the sprocket on and drill through the bolt holes on the wheel
