WTB Peugeot 1979 103 speedometer and speedo cable
Need original speedometer and speedometer cable. I have the gear.
Re: WTB Peugeot 1979 103 speedometer and speedo cable
You will probably never find one that still has the needle attached. They unfortunately made the needles out of some kind of non UV resistant plastic and short periods in direct sunlight turned them into powder and they crumbled away. Still good for a nightlight and mileage counter though.
Ok thanks. Can I switch out to another gear and speedo off another moped model that would work on a Peugeot? Or is the venture a lost cause...
Bump
I think this setup is the best cheapest way to go. You trade out all the components for whats in this party pack and at least you will be pretty close to accurate on your readings. The top unit looks like it should swap into the rubber housing on the Pug bracket.
pug style
Perfect thanks for all your advice cheetahchrome!!! I will move that direction.
