Derbi PP loose needle rollers wanted
todd amundson /
There are to wide needle bearings in the case. When rebuilding, I found most of the needles floating around in the case. The ones I was able to collect show that they passed through gears and got thrashed. I need new ones to load back in the cages for reassembly. Anyone know sizing on these?
Also the pedal chain in there snapped. Anyone know the chain size so that I may install a masterlink to get it reattached?
Looks like 35???
Re: Derbi PP loose needle rollers wanted
I think the tomos chain is the same pitch, but you might have to make it the right length. Also you may want to try to find a couple replacements for those roller bearings if you can. They look pretty crusty.
Measure the ID-OD and width of those needle bearings and order the whole thing. If the rollers have fallen out they're toast. The bearing number may be in the parts manual, but I don't have access to that.
I think i have some new chain , and i think i might as well part out my broken case’s internals , will follow up with you soon.
Downhill Harvey (OFMC) /
todd amundson /
ID 16mm OD 19.6mm W 43.5mm
Yeah those don’t exist. I’m probably going to bore out the main gear to take a 16mm ID drawn cup bearings or two. Then use my existing needles for the rear input shaft. How’s this chain going? Many of the 37 links are cracked.
