FS: vespa bottom end with mazzuchelli crank ALSO CHEAP
campeona del mundo (supercharger pappardelle) /
vespa bottom end with 12pin mazzucchelli anticipato race crank. the cases are untouched and in good shape except one of the coil mount threads was stripped so it's been drilled and tapped to the next size up. mazzy crank is slightly out of true and causes vibration. malossi teflon/viton seal. new condenser and points worked great til i pulled the bottom coil off for another bike.very low mileage on the crank...if you have a diall gauge and some v blocks you can pop the crank out, true it and toss it back in for a super budget start for a ripper vespa build. $69 shipped to your door!
(edited)
Re: FS: vespa bottom end with mazzuchelli crank ALSO CHEAP
pending
sold
