damn, i got the wrong one, looking for an a35 or a55 countershaft, i have an a3 one for trade, and an a3 clutch bell.
I think you can actually replace just the one gear on it
im not sure on the interchangeablity of parts. from what i can tell is the gears on an a3 r thinner/slimmer than a35/a55 stuff, the cluthes r thinner as well. sadly don't even have a gear to check.
I really need a crank...
I have a few countershaft a3 and a35...
I will see if I can dig one out of the squatch hole...
I am almost positive that the one gear can be swapped and it will work...
> work...
Which crank you need? Pat, pm me later tonight/Thursday morning. I'm sure I have the cluster you need. What's wrong with the A35 cluster you have?
i have the a3 countershaft (pictured) angled cut first n 2nd, thinner too. the a35/a55 are straight first and angled 2nd, thicker.
unfortunately dont have a good crank laying around.
Yeah it doesn't even matter which crank I have a whole bunch of engines without cranks but yeah I almost positive I can dig up the cluster
I found 2. You can get a working out of.
1 has the 1st gear chipped.the other the 2nd gear is chipped...
let me know slew how much u want for the pair of countershafts shipped to 92844, thanks
The tranny chain is varied make sure they mesh right or it will jump....
still looking, anyone holding onto a good useable condition one w no chips and no salsa?
^so its pieced together now, first and second gears off treats, and a countershaft off slew.
note: a3 shaft is shorter about 1cm than a35/a55 shaft.
now onto clutch stuff.
if anyones intersted in this looosy , chippy, countershaft lmk cheep.
I got a bare a35 one if you want it... No. Gears nothing but the shaft.....
I might need a a35 gear lemme take it apart.
Did you torque it to spec twernt lbs it was Newtons.
