Carb lot - Mostly dellorto SHA & PHBG
Jimmy Cincinnati /
You get everything pictured. I believe there is enough there to build 2 complete 14/12 sha carbs along with most of a PHBG 21mm carb.
In the bag is a malossi carb top to make the tight clearance of a honda Hobbit.
Also included is the slim angled Malossi air filter needed for the carb to clear a Hobbit.
The PHBG is missing the slide, spring, cap, and chock assembly. It does however include a needle.
Ask any questions. Again, everything you see. $60 shipped.
(edited)
