2 Speed Express motor/trans
Complete motor and rear wheel from a 2 speed honda express for parts. Part out or whole. Has a bad clutch, cant remember if its the 1st or 2nd.
Re: 2 Speed Express motor/trans
Bump
Someone save this from the scrap yard!
Smoeone needs to buy this and convert their older wind-up spring start to kick start. No more broken springs to replace and have a two speed to boot.
Jack Rutherford /
Price?
Its going to be pricey to ship especially with the wheel. I'll do $45 to your door
Jack Rutherford /
Pm sent
> your door
I doubt you can ship it for $45...
> Seth B Wrote:
> to
> > your door
I know, right?
I'm sure Jack would pay for any extra shipping cost though.
Damn, shit I'd even take it for $45 shipped.
That's gotta be a typo.
Did someone grab this or hwut
For $45 I woulda made a powered wheelbarrow outta it.
Cam, sent you a message
Everybody chill!! I'm a warehouse manager so I can pass on those savings. Could be a little extra to the east coast though.
Sold!
Jack Rutherford /
Yeah, I threw in a little extra because I thought there was no way it could be shipped for $45 but Cam is well ahead of us.
Fucker! I needed that ;)
Jack Rutherford /
She's a runner. 2 speed with points ignition and regular kick start.
Hell yeah Jack! Love to see my junk get used.
Excellent job Jack! Looks like it came from the factory that way. How ya liking the kick start and 2 speed?
Jack Rutherford /
I like the kick start a lot. Haven't ridden it yet. Raining today. Hopefully take it out soon. I've had a 2 speed before. As I recall, Honda has it shifting at around 12-13 mph. I wish it would hold on to first gear a little longer.
Sounds really solid, great job.
I really wanted to swap the kickstart to my express but the whole tranny needs swapped because the kickstart side cover won't go on the one speed trans. I found that one out the hard way.
What did you need to replace to get it going?
Jack Rutherford /
crank bearings. clutch was fine. While I was at it, I put in new seals, piston, rings, and gaskets. Honed the cylinder as well and added a spacer to the base gasket. Sanded the front of the cylinder down some but more to go. Oh yeah, it previously had gear oil in the trans. So I had to clean that out. And the wave washer was missing.
At least I think clutch is fine. I've only heat cycled it a couple times and then weather has prevented road testing so far.
Three options that I can think of:
Run thinner oil.
Lighten the clutch shoes.
Stiffer clutch shoe springs.
Edit: remove clutch pad material to reduce circumference. Not good but if you have extras its free. (edited)
Gary Christensen /
Hello!have you sold the express parts!
Need a donor for a project!
I am located either Denver Co
Or Rapid City SD!
Jack Rutherford /
Finally a shake down ride with the "new" 2 speed engine converted to points. I love that first gear!
Jay Krawchuk /
Where did you source piston and rings? Have a 78 that might need rings and am having trouble finding them here in Ontario Canada.
Jack Rutherford /
any 40mm piston and ring set should work. So don't get too picky. Just check the ring gap. I'm actually using a qt50 piston and rings on this Express. The qt50 piston doesn't have that stupid divot in the piston crown like the stock or stock-like Honda piston does. And the qt50 piston comes with better circlips for easier installation instead of the "C" circlips. Amazon sells a bunch of scooter 40mm pistons which will work as well. They are a little bit taller from the digwell to the crown. Just install and check where the piston is at TDC and maybe add a thicker base gasket or a second base gasket if needed.
Jack Rutherford /
I should add. Any 40mm piston will work as long as it takes a 10 mm wrist pin.
