crank bearings. clutch was fine. While I was at it, I put in new seals, piston, rings, and gaskets. Honed the cylinder as well and added a spacer to the base gasket. Sanded the front of the cylinder down some but more to go. Oh yeah, it previously had gear oil in the trans. So I had to clean that out. And the wave washer was missing.
At least I think clutch is fine. I've only heat cycled it a couple times and then weather has prevented road testing so far.
