No, it won't. You are going to rotate the stator to a point that you can adjust your points through the window. You are then going to put it back in the correct position. Your gap is set now so you dont need to have it line up anymore.
The electrics came in 3 main types of Bosch magnetos. 6 wire which is most recent and common. The 1976 to early 1977 5 wire style and the really early pre 1976 4 wire. These ignitions do not interchange if you have stick and original wiring on your moped.
