You’re doing something wrong or got wrong flywheel, The keyway on aftermarket crank is the same, actually the point gap setting @ full open is just past top dead center so all you gotta do is rotate the flywheel until the points are full open,
You may not be on the keyway, didn’t find tdc correctly, you got something going on wrong
