> Don M Wrote:
> No, you give up way to soon....that magneto assy is old style..it is
> either an old 5 wire style or and ancient 4 wire style.. How many
> wires do you have coming out of it and poking through the engine 4 or 5?
> It seems to me that the 4 wire style had flywheel holes that don't line
> up very well with the points.
> Take out the screws in the stator plate completely and rotate so you can
> adjust point gap against the lobe. Gently slide and align your flywheel
> onto the crank but dont intall nut. Just hand install. It doesn't matter
> at what point in the revolution the stator is as long as the points are
> at the top of the lobe height. Adjust your gap. Remove flywheel. Now put
> your stator back in place and screw it down but not too tight. Replace
> your flywheel and tighten. Adjust your timing using an ohm meter. You
> will have to rotate your stator and then final tighten the screws.
It’s a 4 wire. I’m not sure I understand your instructions however. Wouldn’t no matter what I do with the stator, the top of the lobe height would still align with a blocked point of access because it is attached to the flywheel?
