Yes Steve I mentioned that that's the main drive gear and if you're going this far replace all the roller bearings you might even want to open up that main shaft and replace the kickstarter cage so you know everything is Tip-Top that way you know everything is Tip-Top and if you blueprint why you're doing it it will last forever you could even custom make the hubs overwinter for the clutch what you do is you take an angle grinder and cut a three pin slots vertically in between the slanted stock A35 slots then you can use either shoes and if you want it to really really move you make it so they open toward their direction of spin so they get extra grip you don't really need to change the Springs unless you really really kid it out
