Re: Feeler: WTT New Kickstart A55 for Pedal Start A55
♣Slew Foot♣ /
The transmission gets a longer pedal shaft so you need a trans cover with the hole.
You need a pedal shaft with cranks and pedals...
Ref...
This remains the same...
the main drive gear gets one with ramps inside case.
So it's like a total of six parts but you do have to disassemble the engine case so you might as well put in new bearings and seals and upgrade whatever you want blueprint put it back together
