# 719 key
Karen Murphy /
Is anyone with a Lazer Moped who has the key number 719 willing to have it duplicated. I will pay cost for it and shipping to get it. Please help thanks so much.
Wheel and gas cap locked. Been stored many years.
Re: # 719 key
Probably Fred /
You could reach right underneath cap with a small blade screwdriver, give screwdriver handle a twist and it opens right it up
Can’t post a picture at the moment but when I can I’ll show you where to put the screwdriver, you almost ever again need a key,
Re: # 719 key
Karen Murphy /
Hi, dont want to do that. Thanks. Still will need key to use bike to get around at some point.
Re: # 719 key
Probably Fred /
Ya OK enjoy the old gas and then not being able to work on it because you have a closed mind!
A flashlight, a look underneath and a screwdriver could get you going right away with your project,
It’s only Mopeds!
Re: # 719 key
I believe the blank you need is the hillman dc3.
Re: # 719 key
Blake Totally a real doctor /
I have some but I'm not in town.
Re: # 719 key
Karen Murphy /
Hi, if poping gas cap is the answer. I dont think so. I haven't riden this bike in a very long time. But if I remember the cap and ignition was same key. Reason I first posted question was the wheel was locked and need to unlock it also. Someone got into my bike when it was stored used it locked the wheel. I never did. Key missing.
Re: # 719 key
You can pull the pin from the gas cap hinge and the cap will come off. If you have a locksmith in town they should be able to make a key using it. I have a 459 if anyone needs a copy...
Re: # 719 key
Dang Saab, thanks for that tasty tid bit
Re: # 719 key
Karen Murphy /
Thanks. Christian but I still want see if I can find key . I believe it unlocks both ignition and gas cap. So I dont want to go though expensive process of taking bike somewhere to do this.
Re: # 719 key
wheel lock key is different from gas cap key.......so you will need 2 keys. gas cap is easy to bypass without a key, and not destroying anything. fork lock is a different story. hit up DOS cycles with a text of what you need they may be able to help. love my lazer, good luck!
