WTB 1980 or later model NC50 Keihin Carb Either PA08E-A, PA08E-B or PA08D-A
Looking for a 1980 or later model NC50 Keihin Carb.
It needs to have the oil injection hose going into the carburetor at the throttle slide area.
I'm looking into getting rid of my auto choke and running a normal cable choke system. So i'm not looking for the 82-83 version that has the auto choke mechanism.
Keihin PA08E-A
Keihin PA08E-B
Keihin PA08D-A
Re: WTB 1980 or later model NC50 Keihin Carb Either PA08E-A, PA08E-B or PA08D-A
Sean Daugherty /
Anyone got one?
I parted an 80 with 600 miles on it. Will have to dig out the carb.
Sean Daugherty /
Dang only 600 miles! just let me know if you find it. Thanks!
Sean Daugherty /
If you have all the choke items and throttle stuff I would take that too. If the carb ends up having the oil inlet. Thanks again.
Sure thing. I haven't forgot about ya. I'm on a road trip and it will be a couple more days before I can lay my hands on the parts
Sean Daugherty /
Okay awesome! Talk to you in a few days man. Enjoy your road trip!
Carb is a match and in very good condition. Motor was running when parted @ 533 miles.
Choke cable is seized. Filled jacket with oil to see if I can free it up.
Are you wanting the throttle tube/grip & switch assembly with choke lever too?
Sean Daugherty /
Okay, let me know on the choke cable if you can get it unseized. I don't think I need the throttle tube/grip & switch assembly. I have a throttle cable now for the auto choke carb and i'm going to try and mount the choke lever just to my handle bars somewhere.
Thanks Chris, just let me know on a price and if you can get that cable free'd up!
> free'd up!
Take pics of the front and bottom of your current switch assembly please. I'm wondering if they are the same or if there's a place to mount choke levet to yours.
Does your right switch pod look like this? Choke lever is comprised of two seperate parts bolted to switch pod at a pre determined length.
(edited)
Sean Daugherty /
I think my throttle/control has the screw holes for the choke lever to mount to. What do you think? It looks like it should just screw in like the earlier years.
Yep it will work.
Got your payment Sean.
Sold!! One carb, cable and lever for 1980 NC50 Express. Thanks man and I'll be back with tracking numbers tomorrow.
Sean Daugherty /
Thanks for digging through all your stuff and finding them Chris. No rush on shipping! Thanks man!
Pics for refference upon assembly. Choke plunger, spring and black threaded cap are installed on carb. You will need to remove and connect cable then reassemble.
Sean Daugherty /
Awesome, thanks for being thorough! Excited to get this. Thanks man!
Also, here is pic of order of lever with washers. Wave washer goes between lever and perch. Flat washer then bolt together. You will re use your existing bolt on small cable bracket seen to left in pics from yesterday. Tracking numbers as promised. I shipped two items out today and yours is one the bottom of receipt.
Thanks again Sean,
Chris
Sean Daugherty /
I got the carb today. Thanks Chris! Excited to get this cleaned up and on my express.
> on my express.
Sure thing. Let me know if you need any other assistance. Thank you Sean
