Thanks!
Thanks!
You know if you take a second short Bing intake and cut the flange off and clean it up you can make a spacer that works perfect....
> Bob Selby Wrote:
You know if you take a second short Bing intake and cut the flange off, sand both surfaces flat, clean it up, use two gaskets and longer screws/bolts you can make a spacer that works perfect,
Fixed!
> Fixed!
fuck thats great
Thanks! I didn't understand the other post. You're basically talking about making a riser, yeah?
In the same vein as this (obviously except for a piston port): https://www.treatland.tv/MLM-puch-polini-intake-riser-v2-p/mlm-polini-intake-riser-754.htm
righteous.
