FS: nos vespa 43 mm cast iron malossi DEPS kit
campeona del mundo /
yup...a sad day. time to let go of my super sick and rare malossi "mini" deps. this kit is identical to the 46mm alu version porting wise. way sicker because you dont have to bore stock cases or run malossi or polini cases. same threading exhaust flange so you can use the 27mm guys for real flow! i bought this in italy a bunch of years ago and it wasn't cheap. piston is 12pin. $200 shipped to you.
Re: FS: nos vespa 43 mm cast iron malossi DEPS kit
cool
How many miles are on this kit would you say? I'm intrigued.
0 miles baby. it's nos
Siiiick
OMG so much space around the studs. What is the bore? Stock ??
43mm
It says in the title dumb ass, try reading instead of typing. Also good deal on this kit, never going to find one like this again. Glws
Long day at work. Right 43 mm. What a great kit.
pending
ugh, sell already so i'm not tempted.
You and me both!
Me too !!
Dirty30 Dillon /
I have more rare/high output Vespa motors waiting for builds than I care to count, and yet I still somehow can't stop droolin.
Hit that split port with a dremel cuz there's a lot of power to be had
TRES RAYOS. ADAM S. /
Thanks Will!!!!
Congrats on owning the kit.
adam is the new owner of this...make me proud man. the only reason i never ran it is because i only run 10pin cranks. also, the exhaust port looks like it wants porting real bad BUT you have to be incredibly careful not to narrow the bridge or you will blow through into the bottom cyl stud. my plan was always to just run it as is for a few hundred - thousand miles then pull it off and give it some love. definitely get yourself a 27mm exhaust flange and take advantage of that large exhaust port.
