Coming soon for sale next weekend. Items will be placed on Ebay with Ebay's buyer protection etc. (Don't PM me before hand. I know money is tight so start saving up)
1)Koso: DL Style Universal Tachometer
https://kosonorthamerica.com/shop/applications/motorcycle-mx/dl-style-tachometer/
2) 60mm GPS speedometer with gauge mount
https://www.amazon.com/dp/B01NBXJ4T2/
3)VM18 Hobbit Kit
https://www.treatland.tv/mikuni-vm-18mm-p/mikuni-18mm-vm-round-slide.htm
https://www.treatland.tv/malossi-E12-p/malossi-phbg-e12-filter-041418.htm
https://www.treatland.tv/MLM-puch-hobbit-VM18-clamp-style-intake-PHBG-p/motion-left-intake-121.htm
4) OKO 21mm BLK BLK with or without new jets/needle kits (carb used for less than 5 min)(nothing wrong with them. If there is contact Treatland.TV to stop selling them)
https://www.treatland.tv/OKO-21mm-carburetor-p/oko-21mm-black.htm
https://www.treatland.tv/polini-PWK-10-pack-MAIN-jets-100-to-118-p/polini-pwk-mains-370.0003.htm
https://www.treatland.tv/polini-PWK-5-pack-box-of-idle-jets-p/polini-slow-jets-372.0004.htm
https://www.treatland.tv/polini-PWK-carburetor-needle-SET-p/polini-pwk-needles-342.0129.htm
5)Honda Hobbit Malossi 47 Water-Cooled kit/Engine
Used excellent condition kit with stuffy crank and new crank bearings ready to install on your cases. Or I can assemble with cases w/ new crank seals. Just install your variator/clutch and ignition and intake and go.
6) Stage6 Peugeot Speedfight Kit with 10mm stuffy crank and excellent Athena piston
Couple of very small nicks on the cylinder. Did not affect performance at all. Only reason why I am not using it is cause my welded cases developed an air leak around the welds and I destroyed the cases trying fix them with Alu-Weld/Torch/
https://www.amazon.com/dp/B079W4Y136/
Same bolt pattern as the Hobbit. Must add material to the cases. Comes with spacers and an exhaust flange to weld on. Capable of 70mph. Have video proof on youtube using this kit and the VM18
