I blew mine up (sad face)
Why not just rebuild it? So easy a caveman could do it in an afternoon.
Unless the case is broken a caveman could do it
def an option. was kinda curious what an e50 went for. if it costs less to get one than rebuild one....
Keep a eye on craigslist, sometime you buy a whole parts bike for the cost of a rebuild and you still have the extra parts.
I found a Free spirit that wasn't running for 125. but then i went and got it running...by just going thru the carb.
so now i have two mopeds :)
Super easy to rebuild! All you need is bearings and seals.. maybe 35 bucks? A little more if you want to replace hardware and stuff.. then easy to match to a kit if you desire. If you need anything let me know, I’m in Hopkins, MN. Also, check the wiki for rebuilding an e50. It’s seriously a few hours of work, even for your first time.
thanks guy - in st cloud. my issue is I need a new crank because i gauled the small end bushing. so i need a crank,seals,piston to rebuild.
EDIT: I also lack most the specialty tools. so that's adding to my cost as well. see here https://www.mopedarmy.com/forums/read.php?6,4290096,4290503#msg-4290503 (edited)
Nathan, I can help you out...
Call or email
Don@sundaymorningmotors.con
> then
> know,
> rebuild.
> as well. see here
Was this on a kitted bike? And you don’t add tool the to cost because you will need them again.
nope - not kitted
Put in or have some one put a new bushing in it if the rest is good
Don M can help you, good guy and they will have most if not all of what you need.
Shoot, come down here for a ride! Tons of us have the tools to help ya rebuild it, and I’d give you a stock crank for free.
if you serious, pm me. i'll come down there.
