maxi and magnum one I've tried don't work, maybe a different style maxi cap or a maxi N might work, but I don't know for sure.
Should be the same as maxi unless you dont have a magnum x gas tank.
ya dude, i sware mine was fucked and I used a maxi....idk I’ll check later
I think it is the same as a maxi cap, but the one I tried had the rolled edge that helps hold the rubber seal in, and it contacted the lip of the magnum x tank filler. A different maxi cap might work perfectly fine.
> later
thanks, that would be cool to know which one fits
I have the cheapo treats repop on mine im pretty sure. Just make sure you de bur the edge as it will slice you open like a razor
repop maxi on magnum x? i didn't see one for a magx. you wouldn't happen to have a link would you?
Definitely same as maxi gas cap
cool thanks. I'll just have to find one that works
that's good to see. guy i bought the bike off must have had some oddball maxi cap which is why it didn't fit.
Could have been a Pinto cap. Those are different or from a different moped brand completely.
