Basically an unfinished copy of the set-up terrydean and naz built a while back. Unobtainable plastic tfr flywheel fan (just the fan) and a lathed aluminum disc for a hub. Pretty trick if you are setting up a ktm50 or other mini-rotor set-up on your Vespa moped. Experienced builders recommended. $40 Thanks for looking!
