slewfoot taking requests
♣Slew Foot♣ /
I have a stock pile of parts that I've been hoarding mostly older stuff Saks batavus A3 Tomas a few pook and I have one bike and three projects I am still waiting for his insurance company to actually get back to me about my bike they took it for an appraisal and never brought it back nor did they take the paperwork for it Aya just rebuilt the entire bottom end I also read it all the clutches new CDI stator flywheel new control box it had the wicked old controls on a short bar custom exhaust everything it was running the best that ever was and then whammo some idiot that couldn't wait 10 seconds
So yeah if you're looking for a sax brake switch for a 504 that also serves as an exhaust bracket I have it you need that weirdo cev control for an A3 from 1977 you need ah Puch Superman lens new in box do you need stock Thomas pipe do you want some OEM cylinders or OEM Pistons OEM Staters 4 Tomas some sax maybe a bad of us maybe a Puch PM me or holler
Re: slewfoot taking requests
♣Slew Foot♣ /
Rims rims rims buckets of buckets weirdos cev Deluxe ancient headlight with switch some Speedos some actually work Domino and magora controls
Any Korado parts?
#2 puch piston?
♣Slew Foot♣ /
Now unfortunately no piston 4 Puch and the only thing that I even have that's even close to a 42 mm piston would be Wide Open port Puch hero kit which is 43.5 millimeter I think off the top of my head but I already have two cases carved up for it one at Tomas an e 50. O bunch is of case halves for Tomas and batavus a few 505 bottom ends
Do you have the coaster brake rod for a sachs? Perhaps even that weird rear brake light switch that gets pulled by the brake rod, mine seems to be non functional.
> be non functional.
You can adjust that brake light switch. There's a procedure for it in the owner's manual.
♣Slew Foot♣ /
I have the exhaust bracket w/switch but the brake rod is stay in with the grimeacas and project. Frame.
I need a clutch tension spring for a Sachs 505 .I took the clutch cover off and the bushing was there but no torsion spring Please let me know .Thanks
Any star rims Slew?
Not sure about what works on what so maybe you know.am thinking sachs and western flyer are connected some way since western flyer was made by columbia..i need a few things for 79 western flyer..might need front and rear rims if mine does not clean up good enough ..need a speedometer for sure and might be another thing or two i will check on when i get back home friday.
♣Slew Foot♣ /
No rims sorry.
I have a maroon speedo bracket.
Clutch springs all gone ...
> ♣Slew Foot♣ Wrote:
> No rims sorry.
I will need the speedo itself .the needle is broken off on mine..
mark gonzales /
Do you have a stock a55 top end?
♣Slew Foot♣ /
A3 and A35
