FS Motobecane Malossi Variator
Selling a used Malossi variator for MBK. Less than 200 miles on it! Without clutch version. $120 shipped firm!
Re: FS Motobecane Malossi Variator
Would this be worth putting on a stock engine? Or is it a performance item?
kevin smellaflange /
200 miles...with no no clutch action ...what does it do...act like a dymoby?
dimoby still had a standard clutch like a 50v diddnt it? or was it the one that worked on belt tension for clutch action? ie belt loosened and slipped at idle.
No clutch function means you want to pair this with a clutch pulley
Best if you match it up with a kitted motor. But can work with stock, just over kill...
if it's overkill, then what's the point?
Kevin just stick with your stock variator. I don’t want to sell you something that you have no clue on.
Bump! Still up for sale.
