Anybody holding one?
Ive been running a cheapo kit from ebay (like $40 shipped) and im pretty happy with it. Have roughly 500 miles on it thus far. Not a blaster of a kit but it gives you better low end for sure. Just something for you to mull over.
> mull over.
I was considering the "Niche" kit from Ebay for $60, but supposedly they are just copies of the stock cylinder with an overbore and messy porting
For under $30 its not a bad deal. You cant barely get top end gaskets for you stock cylinder much cheaper.
Its not life changing but its something and its cheap.
> Louis Brunskill Wrote:
> I have this on my QT. Not bad! I did a fair bit of porting. And used the
> stock head with a widened chamber and squish ring set up the way I
> wanted it. About. .035 it runs great!
Which kit is it? Do you have better pics of the bore/ports? What kinda speeds?
That's all the pix I took.. sorry. It has great torque! But it's still a bit lazy up top. Stock pipe is the main cause of that. It goes 35. 99% of the time. I'm 190lbs.
