WTB A3 flywheel!!
Drew Matthews /
In search of an A3 flywheel. Mine spun and the lock pin absolutely demolished the inside of the flywheel. Get at me!! Located in Northern WA. Willing to pay for shipping.
Re: WTB A3 flywheel!!
Which flywheel do you have? They're different ones.
Drew Matthews /
Hmmmm, I believe it’s a Ducati flywheel. What different ones are there?
♣Slew Foot♣ /
Well the earlier models actually are flipped 180 degrees whereas the later models are comprable 2 + a three fives 2 coil and have the same orientation as every other Tomos also if your case has four Mount holes instead of three you can get a CDI one that will replace it that's 12 volts you can run all your stuff at 12 volts all your 6 volt stuff will work with 12 but if you just need a flywheel post a pic of the stator
Ducati, CEV, ZEM, and ISKRA. There were like three different models of CEV ignition used, and the diameters are different so it's important to match the correct flywheel with the stator. (edited)
