Ciao (all) Vespa Malossi Variator and Variated rear gearbox w sidecovers.
Any Grande, Bravo, Si or....Ciao! (read on)
Malossi variator and shaft and both fixed and moveable faces, guides, spacers, at least a dozen rollers, yellow contra spring.
Complete transmission for variated rear gearbox (10.73:1 iirc) with whole clutch and pulleys, stock contra and the stronger stock bell.
If you are doing this for your single-speed Ciao to make it dual-variated, I also have a pair of Ciao "variated" sidecovers!
As of today, our family Hobbits outnumber our Vespas 5-to-2 so I can let all this go now and then get mad about having done that, later.
Piecemeal (eBay, Retailers, CL, MA, etc), it's all worth about $350 +shipped at the most, but I didn't pay that much and neither should you.
Part trades are fine with me too...
I need 81-red hobbit floorboards, a chain side black hobbit sidecover.
I need a plug and play, running, stock (or ported/kitted) Hobbit CDI motor w stock -II carb and -II vario stuffs.
I need a complete hobbit speedo cable w good caps.
I need good left-hand hobbit controls/switches w clean wiring assembly.
I need a clean 41mm or 43mm fan-cooled V1 topend.
I need a black Ciao floorboard. (edited)
Re: Ciao (all) Vespa Malossi Variator and Variated rear gearbox w sidecovers.
Alexandro Ramirez-Nagy /
Pm'd
I built a pa50 motor last night so I'm covered there. Still into other part trades though.
front vario stuffs, gone
sidecovers are on hold
rear gearbox/trans/clutch/pulleys/bell still available
I’d like a rear clutch and bell plz
Also a bravo var side cover plz
side covers are gone
clutch stuff pending
clutch stuff swooped
