1995 Bravo EEV2t. No longer has the is motor and has a single speed transmission. Motor on it is 6v points motor, wired for spark, but wiring will need to be gone through for lights. May be a 77' 43mm kit, but I have a stock dykes ring to pend somewhere. Was running before sitting, probably needs carb cleaned maybe jetting because it had a different pipe. I have a factory long seat if preferred as well as one of the stock purple sidecovers. Neat factory color, the frame and wheels have flake that really pops in the sunlight. Located in St. Louis, MO
