whatever else you might have that's not the stock rubber.
-O7O' (edited)
-O7O' (edited)
How determined are you?
Stephen... Let me know what you have. I'd really to like to run my new build on anything but rubber.
Bump out to any Garelli parts hoarders ; ) I've got a build going with a brand new NOS case, 70cc Polini, 19 phbg... and I'd really love to have a real clutch...
... let me know what you have the you can part with... Trickmetric, BRN, clutches, etc.
I have a V1 bell ready to go, as well.
> clutches, etc.
If you don't mind running the V1 bell and spacer set up I can fix something up. If I don't have a brn I have a KTM and I'm working on something else also. Everything I will be able to come up with will have to run a clutch cover spacer though
I don't mind running the spacer... V1 and BRN sounds good to me.
Longer term, I have a KTM clutch... and am in the process of finding someone who can re-create a hub with the splines to fit the crank. I don't like the weld a washer approach.
I actually have someone that cut spins in a few KTM clutches a while back. I'll see if I can get him to cut more.
https://www.mopedarmy.com/forums/read.php?1,3935323,page=2
Pics are in here of some of the clutches I've been playing with.
This is what I've been playing around with lately
https://m.facebook.com/stephen.simmons.37/posts/pcb.1215631085235157/?photo_id=1795931823761806&mds=%2Fphotos%2Fviewer%2F%3Fphotoset_token%3Dpcb.1215631085235157%26photo%3D1795931823761806%26profileid%3D100000350164677%26source%3D48%26refid%3D18%26ref%3Dbookmarks%26_ft_%3Dqid.6677851174208124322%253Amf_story_key.1215631085235157%253Agroup_id.430721387059468%253Atop_level_post_id.1215631085235157%253Atl_objid.1215631085235157%253Acontent_owner_id_new.100000350164677%253Asrc.22%253Aphoto_attachments_list.[1795931823761806%252C1795931860428469%252C1795931987095123]%253Astory_location.6%253Astory_attachment_style.album%26__tn__%3DEH-R%26cached_data%3Dfalse%26ftid%3D&mdp=1&mdf=1
I have one. it was used in a kick start engine though so I don't have the starter ring.
it's worth $220 to me- but you can come pick it up in Decatur.
Is this for the Garelli bell? or other?
stock noi bell. It's one of the first batch of the noi hammers walt did. It has been remachined to fix the shoe spacing problems. Works like a charm. Has the blue springs on it.
> the starter ring.
Where have you been hiding?
> > the starter ring.
sorry homie, it's been in the private collection for 6 or 7 years
