This thing, but not cracked, shipped to 68131
^Even through the one Angello pictured has 4 bolt holes to mount the plate it should work on a motor that only has 3. I did this recently and it bolted in fine and bike has been up and running for a while with no problems.
Declan, you're right.
These plates are the Achilles' heel of Minarelli V1KS engines and, when those with three bolt holes break, we replace them with 4 bolt holes ones without encountering any problem whatsoever.
The plates with three holes are absolutely impossible to find, unless someone can recover them from an engine to be dismantled.
