FS: Vespa Variated transmission for parts
Sean Mohoot /
I have a Variated trans that has some issues, would be good for set of cases to put speed gears into, or maybe you can run the current gears?? So here's what's up, when turning the shaft there's a spot where it seems to catch, the output shaft is missing the bearing cup so it seems like it's catching from not being aligned currently, I popped it open and found a little bit of metal dust, but couldn't see any chipped gears. Basically, buy and use at your own risk, if anything it's just being sold for the cases!
$40 plus shipping, will slap it into a flat rate box.
